96 to 89 axle swap good idea?
deezyperformance
Iowa
I was thinking about swapping the axles from a 96 to my 89 I can get the pair
for about what It would cost to just put new shafts with the larger joints in my current 30. Can I assume that it has the larger joints and a 29 spline 8.25
as long as it doesn't have ABS. Is there anything else I should grab off the 96 since I can get it cheap?
96's will have the larger u-joints and you will eliminiate the godawful CAD as well with the newer axle.
I'd grab the brake booster as well, its bigger than yours and helps braking.
