Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old August 7th, 2017, 11:43
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Re: The force was strong with this one, Oil filter nightmares
Originally Posted by Hypoid View Post
I use Chrome. I opened the page with IE and can see the pictures.
Regarding the supposed photos in post #1 there is no indication there was ever a photo when viewed with the browsers listed below.
As to the posts with links, the following are the results with various browsers.
Chrome---NOPE. Tiny, very tiny black square on an all black page.
MS Edge---NOPE. Blank white page.
Internet explorer 11---NOPE. Blank white page.
I'll have to check firefox from the computer in the family room.
EDIT: I can see the chick in the white shirt.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Calico 4-Link
'87 MJ 4.0 AW4 231 stock-ish
Old August 7th, 2017, 11:50
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Interesting as the T-Shirt is also a JPEG image like the others I hosted on Naxja's server in my account in post #1, but the t-shirt is hosted on another web site where they sell the shirts.
It must be your all's browser settings or a Naxja issue or a combination? Like I said Google has tons of blog discussions on settings on the browsers that need to be changed to fix it on your end.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 7th, 2017, 11:58
Ecomike's Avatar
NAXJA# 2091
Just for grins does this one show up?
Old August 7th, 2017, 11:59
Tbone289's Avatar
Tbone289 Tbone289 is offline
I've tried to view them on just about every OS/browser combination I can think of (within Windows & Android), and nothing works. I see the T-shirt just fine as well.
CRAZY to tighten a filter that much, BTW. I never tighten them more than I can with my hands, and don't use tools at all to R&R. I've never had one come loose in 30 years.
Old August 7th, 2017, 14:05
dan1977p's Avatar
dan1977p dan1977p is offline
Was the Jeep hot, by chance? Hot jeep makes taking the filter off harder.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's
SeXJ Build Thread
Old August 7th, 2017, 14:59
Ecomike's Avatar
NAXJA# 2091
Nope mine runs at 180-200 F tops. The quick lube place over tightened it using the 1" nut on top of the K&N filter. Rookies,
I just checked the folder these photos are in and the setting is set to public, not private????
Old August 7th, 2017, 15:28
Ecomike's Avatar
NAXJA# 2091
I wonder if you need to be a paid member to view them here now?
Old August 7th, 2017, 17:21
Bent's Avatar
I feel cheated.
Old August 7th, 2017, 19:58
Anak's Avatar
Anak Anak is offline
Mostly Harmless
I paid.
Shoot, I am on the BOD.
Old August 8th, 2017, 15:09
Bent's Avatar
Nope.
Old August 8th, 2017, 21:18
Ecomike's Avatar
NAXJA# 2091
So who is running the Naxja web site? It looks like it is a naxja problem at least in part. While it works for a few of us, it should work for most of us on most browsers. It looks like a code issue to me on the image code page, as the code does not end with a .jpeg or .jpg file name, unless the way this stuff is coded has changed recently?
Does this trick below work?
Originally Posted by Anak View Post
I paid.
Old August 9th, 2017, 02:53
md21722 md21722 is offline
That's a good observation. If I sign out of , I can't see the pictures. When I login, everything looks good.
Old August 9th, 2017, 07:25
Anak's Avatar
Mostly Harmless
If the trick below is that you quoted me, then yes, that works. If there is supposed to be a picture, then no, it didn't work.
Old August 9th, 2017, 10:10
Ecomike's Avatar
NAXJA# 2091
That explains why I only see them in the Firefox browser, it is the only browser I log in from. And I never log into any sites from a cell phone for security reasons. Too portable and easy to steal. So it is partly a Naxja issue, but many vehicle blog sites do the same thing, block image viewing unless you sign in or join. That is why I don't bother browsing their sites!!!!
So folks need to log in to see the photos, like on many other sites. Also some have security settings issues in their browsers they are using, or the IE settings of the operating systems.....
Old August 9th, 2017, 13:47
Tbone289's Avatar
There are plenty of people posting in this thread that are logged in and can't see the pictures...
Ball joint press nightmares Ecomike Tools and Garages 15 April 16th, 2016 11:14
Electrical & bizarre braking nightmares! HELP! semperfi1371 OEM Tech Discussion 4 May 31st, 2011 19:31
Wiring nightmares from the stealership justkain OEM Tech Discussion 5 December 16th, 2010 07:33
Want NIGHTMARES Speedbump96 SoCal Chapter 16 August 18th, 2010 01:52
Electrical nightmares unknown OEM Tech Discussion 4 May 21st, 2003 09:43
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
