Finish my project!
Axle is complete and comes with all required parts to bolt on to a Jeep XJ, TJ, or ZJ. The only things that need to be done are welding on the suspension brackets and a gear setup, which are all included. I have over $1500 in parts and labor invested in this project!
Features:
-Front Dana 44 Differential - high pinion, reverse cut gears - driver side diff ('79 F-150 with F-250 outters)
-Full size - about 67" WMS to WMS (use custom backspaced wheels if need be)
-30 spline axle shafts with 5-760x u-joints
-Ford flat top knuckles - go Hi-steer or use Over the Knuckle setup
-Rotors, Spindles, and hubs - like new
-HD External Warn Premium Hub Lockouts
-Massive Dual Piston Brake Calipers with new pads
-4.10/4.11 Precision Gears
-Powertrax Lock-Right Locker
-New Heavy Duty Rubicon Express Upper Control Arm Bracket Kit, Spring perches with shock mount and Lower Control arm brackets
-Sanded, primed, and painted flat black
-All parts have been sanded and painted
I am located in Santa Barbara, CA 93117. Shipping is available via Forward Air Freight. If you live in CA, come pick it up!
First $800 gets it!
Pictures:
Email me with any questions:
[email protected]
Features:
First $800 gets it!
Pictures:
[email protected]
