mj soa help needed(please)
aldumoul
everything is done, new arms, t-case drop, coils, trac bar, etc; having troubles putting springs in (bushings in place). i can get one bushing in place but im left with not enough room too fenagle the other bushing in the other side... is it best at this point to lower the axle, or raise the frame.?
ps. is it wise to welde the perches prior to putting the springs on?... i was thinking it would make sense to get the springs in place and then put the perches underneath the springs(once i get them in) and then weld
First part- ?????????????? Explain again.
Second- Put it all together and then tack the spring perches when everything is all setup. Then take it apart and weld it.
hinkley
