fasteddieyj
- Hanover, PA
Not sure if this is the right spot for this question or not, but here goes.
First a basic rundown of my Jeep: 88, 4.0, AW4 and 242 t-case, open d30, 8.8 with factory limited slip.
Was out wheeling at Rausch today, and at the end of the day was crawling up a very rocky hill. I made it about 2/3 of the way up and was at a spot where I needed to get on the throttle a little more than I would really like to. The Jeep bounced a little and was followed by a pop, which turned out to be the flange on my 8.8. After being winched the rest of the way up the hill, removing the driveshaft and limping back to the parking lot we got ready to head home. So here's where I'm unsure: I thought that if I put the tcase into fulltime 4wd I would be able to drive home on just the front shaft, but the jeep would not move in any forward gears or reverse. The rear output spins to the point that the speedo will indicate about 25 mph with the engine idling.
We decided to try 4 hi, and the jeep moves forward and reverse. Ok, good to go. On the highway though things were different. I had my foot to the floor and couldn't do more than 50 mph. Two other things were happening on the highway also: the jeep sort of jerks around, and there was a grinding/whining sound coming from under the shifters.
Ended up getting it home on my buddies trailer and got under it tho really take a look at things. I found that the tcase fluid was about 1/4 - 1/2 inch below the fill plug, and it was full when I checked it this week. Also the cross member that the tcase mount is on has been pushed up about 1" in the center.
Now my first thought is the the tcase is shot, either from a shock load when the axle flange was broken, or from being hit/the cross member being bent.
Any thoughts anyone might have on this? Sorry for the long post.
