Old October 11th, 2017, 19:18
Precious88xj Precious88xj is offline
Turning engine by hand it doesn't feel right
So I swapped in a ho engine into xj and now that it's all plugged in I'm realizing something doesn't feel right. I'm turning it by hand and I hear a noise in time chain area and when I'm turning the engine not only do I feel resistance but it springs back. Is that a bad timing chain?
Old October 11th, 2017, 19:34
old_man's Avatar
old_man old_man is offline
Re: Turning engine by hand it doesn't feel right
Springing back is due to compression and is normal. I would worry if it didn't do it.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old October 12th, 2017, 09:54
Thanks I appreciate it.
New Engine doesn't run right. Fred Jeep Street and Performance 16 November 21st, 2016 19:45
NP242 question - differential in 4 FT mode vs 4H PT mode, turning by hand ANZAC_1915 OEM Tech Discussion 14 August 12th, 2016 19:41
Suspension Still Doesn't Feel Right? Cherokeekid88 Modified Tech Discussion 20 September 7th, 2012 08:24
When turning feel a slight pull in the steering wheel supermini99 OEM Tech Discussion 7 August 5th, 2012 18:14
It doesn't take an engine Metal Thrasher NorthWest Chapter 9 August 19th, 2009 17:48
