Old October 11th, 2017, 08:40
arxmike arxmike is offline
overheating - cooling fan not coming on
I have a 1999 xj 2 door 2wd i6 4.0
It overheats quickly at idle and in traffic.
Light comes on. (No gauge)
It boils over into overflow tank.
Electric fan never comes on to assist with cooling.
New parts I installed:
Radiator and cap
Thermostat
Temp sensor on therm housing
Electric Cooling fan
Cooling fan relay (black fuse box passenger side engine)
Fan will not come on even when i turn on AC ( doesn't cool anymore)
Any ideas?
Old October 11th, 2017, 09:42
Re: overheating - cooling fan not coming on
Also... The cooling fan fuse located near the relay looks fine.
Unless it's a bad wire / connection what else could it be?
Old October 11th, 2017, 10:04
RCP Phx RCP Phx is offline
Test the fan and test the relay!
Old October 11th, 2017, 10:08
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
What year XJ? The electric fan controls are not not the same throughout the model run.
It could be a bad fan relay, a burned out fan or the computer isn't turning that circuit on, along with possible bad wiring.
It's time to do some troubleshooting, get your voltmeter out and start tracing the power pathway, starting either from the fan, and working backwards or at the battery and working toward the fan.
A wiring diagram, from the FSM for your year XJ, makes this process a lot simpler, more productive and less frustrating .
My XJs have manual fan bypass switches, allowing the electric fan to run continuously, if desired. You might try installing one.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, 4.6L Russ Pottenger. stroker, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old October 11th, 2017, 11:41
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
1997-2001 you can test the e-fan function by carefully disconnecting the wire plug from the Coolant Temp Sensor on the thermostat housing while the engine is running. If everything is functional, about 5-10 seconds after the wire plug is disconnected, the e-fan will start and run. The Check Engine Light may come on, but will go out by itself after reconnecting the wire plug.
If you are overheating at idle, you likely need a new mechanical fan clutch. The fan shroud is installed, right ?
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old October 11th, 2017, 13:37
It does have shroud. I will have to try unplugging the sensor while running when i get back home tonight. See if that starts the efan.
It doesn't take long at all to boil over.
As soon as it gets to temp.
Old October 11th, 2017, 14:37
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
You mentioned the ac doesn't work.
Unplug the electrical connectors from the back of the compressor. Then turn the ac on and see if the fan comes on. My understanding is sometimes the low pressure switch on the ac messes with the e fan coming on... but I could be wrong.
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
New cooling system overheating on the highway HWK9USA Modified Tech Discussion 50 September 9th, 2015 14:00
The problems keep coming. Overheating SBpunk OEM Tech Discussion 27 July 1st, 2013 20:47
Upgraded cooling system still overheating? nrpalmer32 Modified Tech Discussion 21 December 23rd, 2010 14:38
Overheating, Cooling Fan question. navistarman1980 OEM Tech Discussion 8 October 28th, 2008 22:32
Still Overheating-New Engine and Cooling System Nevada City Sparky OEM Tech Discussion 23 February 16th, 2006 09:51
