Old October 10th, 2017, 19:32
jrowell's Avatar
jrowell jrowell is offline
Where do these plug into... 87 renix
87 Cherokee... help me identify where these go. Heater control vacuum, cruise control vacuum and misc plug.
Sent from my SM-G930V using Tapatalk
Old October 11th, 2017, 13:26
90xj06's Avatar
90xj06 90xj06 is offline
Re: Where do these plug into... 87 renix
the heater valve should have a vacuum line coming out of the firewall by the heater or ac hose. it should be red or pink. the big nipple on the cruse control goes over to the drivers side and down to a valve on the brake peddle. and the little nipple feeds from the vacuum canister in the front bumper passengers side.
not sure where that wire goes your wiring looks to be going over the engine.
Old October 11th, 2017, 18:14
jrowell's Avatar
Sweet, thanks for that info. Found that little plug tucked under my dip stick.
Old October 11th, 2017, 18:21
jrowell's Avatar
I see the red/ pink one... any ideas where that black one should be hooked up?
Old October 12th, 2017, 08:07
90xj06's Avatar
im pretty sure that also runs down to the vacuum tank as the feed of vacuum for the hvac controls. it may or may not have been tee'd with the cruise control.
Colder plug for a renix blondejoncherokee OEM Tech Discussion 25 October 9th, 2014 11:05
RENIX plug wires? MoFo OEM Tech Discussion 13 August 27th, 2010 05:22
Best plug for a RENIX and what gap? xjtrailrider OEM Tech Discussion 10 June 19th, 2009 12:36
Extra vacuum plug on Renix TB? jaytee79 OEM Tech Discussion 2 January 26th, 2009 11:56
MPG spark plugs plug GAP & Renix Ecomike OEM Tech Discussion 10 March 17th, 2008 09:07
