Old October 9th, 2017, 09:57
asymptonic asymptonic is offline
Popping the valve cover. Replace CCV parts before or after?
I'm removing my valve cover tonight to do the MMO lifter soak. I also have one leaky CCV grommet, so I plan on replacing that and the elbows at the same time.
Would it be better to try and remove those guys with the valve cover on the engine or off, or does it not matter?
Old October 9th, 2017, 11:35
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: Popping the valve cover. Replace CCV parts before or after?
Depending on how tightly the grommets are fit into the cover, it might be better to take them off first, so the engine can be your "third hand" and keep the thing from wiggling around (and potentially getting oil everywhere) while you're using your other two to pry them out...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old October 9th, 2017, 12:42
lawsoncl lawsoncl is offline
If they're crumbling, it might be better to cut them out after you pull the cover so you don't get crap falling in.
Old October 9th, 2017, 17:18
They're not crumbling, so I think I'll take them out first.
Lines from valve cover to intake, and from valve cover to air cleaner. Dozer11B OEM Tech Discussion 8 September 27th, 2016 18:52
2.5 4 cylinder parts-alum valve cover, alternator bracket BIGSLVRXJ MWC For Sale/Wanted Forum 15 July 15th, 2012 23:03
Moisture in 95 XJ valve cover pcv valve line? not in oil though?? 95cherjustin OEM Tech Discussion 8 December 30th, 2008 09:13
Tricks to remove and replace the EGR Valve? Muddy Beast OEM Tech Discussion 2 May 31st, 2008 17:17
Replace Selector Cover in 93 XJ mbenonis OEM Tech Discussion 11 August 16th, 2006 09:26
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
