Old October 10th, 2017, 20:13
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
99 driver side key/lock sticks with key sometimes
i take it this is straight forward, but i havent run into the issue until now.
put the key in the door, and it does want to turn until after some wiggling.
tumbler sometimes to. original key or years past spare thats still new like.
new lock needed or is something else simply wrong?
Old October 10th, 2017, 20:46
Heavyopp Heavyopp is offline
Re: 99 driver side key/lock sticks with key sometimes
How about some graphite?
Old October 10th, 2017, 20:50
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
x2 on that. I use the spray stuff all the time on door locks.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old October 11th, 2017, 02:01
Ralph77 Ralph77 is offline
X3. I spray graphite every October as part of my winter maintenance. I use this.
https://www.napaonline.com/en/p/BK_7...?interchange=1
I hear Fluid Film might be a good option too but have never tried it.
Old October 11th, 2017, 07:12
ill try the graphite first!
Old October 11th, 2017, 08:25
asymptonic asymptonic is offline
If graphite doesn't work, its pretty easy to take the interior panel off, removing the lock cylinder, and clean it out thoroughly with carb cleaner, etc and use graphite or silicone spray on the inside. I did this on my '98 recently and its never been so smooth.
Old October 12th, 2017, 18:05
JeepNoob JeepNoob is offline
How bad does the key look? You'd be surprised at the wonders simply getting a freshly cut key can do.
Old October 12th, 2017, 21:49
trippled trippled is offline
Yes and no. If you have someone who can look at the key and cut the correct depths then yes. However most of the ones simply trace the key and will cut you a fresh worn out key.
Old October 13th, 2017, 03:52
With any key I always throw the original, or the one that came with whatever it goes to, on the key ring in the junk drawer. Whenever I need a copy made use that key. Thinking being is a copy made from a copy, made from a copy gets you to a point where that the key won't work anymore.
Jeep was broken into, repair driver side lock Magus2727 OEM Tech Discussion 3 June 14th, 2013 17:26
driver's side front door will not lock ericfx1984 OEM Tech Discussion 1 January 23rd, 2011 11:28
WTB: Driver side door lock inside jeepgeek2002 SEC For Sale / Wanted Forum 0 February 24th, 2010 15:13
Driver side door lock ruehmann OEM Tech Discussion 0 February 8th, 2009 20:19
driver side lock won't turn H8PVMT OEM Tech Discussion 0 July 6th, 2008 05:47
