WTB: 97+ 4.0L AX15 ECU
Looking for a 97-99 ish ECU for a 4.0L Manual (AX15). I want a spare on hand before I attempt the needed solder repair mine needs.
I have other combos Engine/Trans 97-2001 ECU if you prefer a trade.
Aren't the '97 ECU's year specific to only '97?
I have a bunch of ECU's but I'd have to check to see if I still have one for the manual trans. If I do, $40 shipped to ya.
IRC they part numbers are different for each year but the function is the same. I can even make an auto ECU work with the manual version, but I prefer not to as you get a check engine light due to the missing TCU. The main diff in the 97+ was the swap in 2000 in ignition styles. Other than that all the sensors should remain the same.
