Ax15 from yj to xj
ljobbins
SD County
I remember reading someone had an easy trick to drill the tranny holes to clock the transfer case to the yj ax15. I searched all over and can't find it. Something about a gasket or something. I would like to avoid having to measure and drill all the holes perfect if there is an easy jig or gasket I can use that will prevent me from screwing it up on accident. Thanks.
Do you or anyone have experience with that jig? And that would be moving it up from the stock clocking position so maybe it would put it in a good position? Is the flatter non stock position from them ok with the new angle?
YJ clocked higher = better IMO.
May need to massage tunnel with a BFH.
