Monroe Shocks w/out bar pins
Undeclared
Bay Area
I am about to install some bpe's and will be putting in new shocks while I'm at it. Does anyone know if there is a Monroe Sensatrac that is the same size as one that fits stock without bar pins? If not, is it difficult to remove the bar pins?
I took the bar pins off my shocks. I was surprised that they were hollow. I shot them with PB pushed to expose one side and cut off the pin (with a grinder, but a hack saw woulr work too) and pushed it back through the other way. The first one was a PITA but after I figured it out the other 3 were cake.
I too, had a hard time finding right shocks without bar pins so I went that route.
easiest way to remove the bar pins is cut one side off with a grinder or a hacksaw, and tap it out. you can push it thru without cutting it, but its a pain in the ass. lube it up with grease or dish soap before you try to push it thru, it will make it go a little easier.
