help, stranded 405 n westminster! need 10mm socket
GrimmJeeper
Gardena, CA
Tegra is puking oil out the valve cover, the gasket looks pinched on the edge by one of the bolts, anyone close that can bring me a 10mm socket so I can pop the valve cover off and try to reseat the gasket enough to drive home??
Call me! 3109959710
I'm at the 76 station that is right off the westminster exit of the 405n
Mike, why didn't you call me? I have a tool kit in the car......I would have headed your way in a heartbeat.
Glad you got home
gasket had a cut in it. pulled the valve cover in the gas station parking lot and reseated the gasket, good enough to get me home. :dunno:
check engine light is still on but thats a battle for another day.
thanks, you were my first thought, then i figured i would post up and wait an hour then call AAA. id rather fix it then tow it. either way im back on the road... for now. see what i get for not driving an XJ? :D
