questions about car turning over but not starting???
blazinjames
hey everyone I just have a couple questions.
I have a 1991 Eagle 2000gtx that will not start. turns over but doesnt want to start. I replaced spark plugs, leads distributor cap and rotor, there is a strong spark. ive checked engine compression and it is good in all cylinders.
there is NO where to attach a fuel pressure tester so I cant tell if the fuel pump is working properly. I have pulled off the line going into the fuel rail and turned the car over and fuel comes out of it. Ive also taken the return line off and turned over and fuel comes out. when I check the spark plugs for fuel a couple of them seem to be a bit wet but it doesnt seem like its getting fuel.
Can I test the fuel pump some other way?
Im wondering how can I test the fuel injectors? could the computer or some other comonent stop the injectors from working properly?
Im really stuck and down no what to do.
Thank for any help
