ghettocruiser
- Norristown, PA
Ok, background to this weird issue. Ive been noticing some breaking up of the engine while driving. Kind of a weird hesitation that was intermittent. The only thing I could track down was the TPS. So I changed it for a new one. That fixed it for a bit.
Friday, on my way to finish my xmas shopping, it broke up real bad, ran ok for about 2 more seconds, then shut down on me. Crank, crank, crank...no start.
Things I was thinking at first were fuel pump, or CPS. I wasnt getting a code, so I figured fuel pump. I got a tow off of the highway were I was stranded...in the pouring rain. Got it home, and after some testing, found out I had no spark.
First thing I did was pull the dist. cap. The rotor was in a few melted pieces. It looks like it was on fire. All inside the cap you could see were melted plastic was slinging around.
The metal contacts that are normall in the rotor were just layin on top the distributor.
I just HAPPENED to have a new distributor, cap, and rotor in my garage, so I replaced it all. The dist. had a lot of melted plastic on it, and since I had the parts, I figured what the heck.
Ok...what the heck could have caused this? I had an MSD coil installed. Is it possible that it went crazy and supplied too much voltage?? The other idea I had was I did some extended highway driving awhile back. Where I was at like 3000rpms for alittle while. Could this have caused the rotor to get hot and meltdown?
Ive never seen this happen before. It was a new cap and rotor that I installed at my last tune up. Which was only about a month ago.
Any ideas?
Justin
Any ideas?
Justin
