Prev Previous Post   Next Post Next
Old November 30th, 2017, 13:00
the_mechanic the_mechanic is offline
Speedometer Needle Realignment
I made the mistake of taking the needle off my speedometer in my '95 XJ and it seems to be mis-aligned now. When I initially installed it aligned with the stop, it was WAY off but then installed it pointed below the stop (and rotated it back around) and it was close to accurate. However, it is still about 5 mph off. I can live with it but I just installed a lift and will be likely re-gearing (3.07 gears and 31s is not an ideal combination) and correcting the speedometer with a new speedo gear. As such, I would like to correct the error in the gauge itself too and am hoping someone has an idea of the best way to ensure my needle is properly aligned.
Any help is appreciated.
Aaron V.
The fleet: 1995 Jeep XJ 4.0/5-spd, 1970 Ford F100 302/C4, 1970 Ford F100 360/4-spd, 1973 Ford Maverick 302/C4, 1979 Chevrolet C30 Ramp Truck 454/TH-400, 1948 Chevrolet 3800 216/4-spd, 2004 Honda Shadow 1100
SYE and needle bearing????? XJinWork Modified Tech Discussion 11 October 27th, 2008 23:10
Speedometer needle wobble/shake mattbred OEM Tech Discussion 8 November 25th, 2007 15:07
.:Speedometer needle jumps back and forth:. JaysXJ OEM Tech Discussion 3 October 20th, 2004 08:34
