Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old April 8th, 2006, 23:57
rpraterxj's Avatar
rpraterxj rpraterxj is offline
Best way to clean/degrease old axle housings
I did a search, but did not find what I am looking for.
What is the best way to get the axle housings clean? I am tearing apart a couple of axles out of 87 and they are caked with grease, dirt, and grime. I started out using just a scraper. I don't have a way to easily transport these things nor do I own a pressure washer.
I am open to ideas.
Thanks,
Robert
Old April 9th, 2006, 00:02
jonboy's Avatar
jonboy jonboy is offline
Re: Best way to clean/degrease old axle housings
Degreaser from Autozone is cheap, plus a stiff brush and a regular ole garden hose.
Shouldn't be too bad.
Old April 9th, 2006, 00:28
O.D. O.D. is offline
scrape the big stuff off and then a wire wheel on an angle grinder.
Old April 9th, 2006, 00:39
TORX's Avatar
TORX TORX is offline
I would use a basic solvent and take a paintbrush and clean it up if you got any tough spots let the solvent soak in and do its job, then use a tooshbrush or wire brush. Wipe it out good or rinse it out depending on the solvent used. I use this method on all greasy parts that need cleaned and it works great.
TORX
Old April 9th, 2006, 05:47
Stahlgewitter Stahlgewitter is offline
Ive had good success with plain old oven cleaner. Should be able to find some under the kitchen sink, just dont let the Mrs. know what you're using it for.
Old April 9th, 2006, 05:52
JLane99XJ's Avatar
JLane99XJ JLane99XJ is offline
and WEAR SAFETY GLASSES!!
wire wheels on agle grinders are easy ways to loose vision
Old April 9th, 2006, 06:03
RCP Phx RCP Phx is offline
Deisel fuel,cheap and easy.
Old April 9th, 2006, 09:05
jjvande's Avatar
jjvande jjvande is offline
couple cans of brakeclean and some wipes/brushes.
Old April 9th, 2006, 09:22
rokjeep's Avatar
rokjeep rokjeep is offline
another vote for oven cleaner. Get the foamy kind and it will do most all the work for you. Spray it on and let it sit for a while then just hose it off and viola.
Old April 9th, 2006, 10:36
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Best way to clean/degrease old axle housings
wire wheel for the big chunks o stuff
palm sander for the finer stuff
then clean it all with brake cleaner before you paint it...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old April 9th, 2006, 11:50
creeperjeep's Avatar
creeperjeep creeperjeep is offline
I usually use a pressure washer on the trucks at work, it takes it down to the metal, but theres a film you can get with degreaser after that
Old August 10th, 2017, 09:15
Tbone289's Avatar
Tbone289 Tbone289 is offline
SPAM-A-RAMA-LAMA!
Old August 10th, 2017, 10:54
TRCM's Avatar
TRCM TRCM is online now
ding-dong
Old August 11th, 2017, 10:11
RWKHausSupply's Avatar
RWKHausSupply RWKHausSupply is offline
NAXJA Supporting Vendor
Strip everything out of them. Take em to Currie, I think its now up to 140$ each, but they look brand new steel when you get them back. They first tank em, then steel abrate them. Literally they look like a brand new housing after.
Just a thought.
RWK Haus Supply
All your drivetrain And Jeep needs at a Discount! Call us for all your drivetrain & Jeep accessorry needs. If it is for a Jeep we can get it for less and with superior service. Yukon, USA Standard, Motive, Ten factory, Detroit, ARB, Teraflex, Rock Krawler & A LOT MORE..
All items ship FAST! ~ http://www.rwkhaussupply.com ~ Robert@RWKHausSupply.com Free shipping on Rock Krawler kits. Dana 30 no question asked 1yr warranty axle kits FOR LESS!
Old August 15th, 2017, 12:41
md21722 md21722 is offline
A cheap pressure washer will do a wonder on them. Sure you could wire wheel and brake clean but that is slower, more expensive, and more messy. If you have access to a garden hose, the $79.99 one from HF will work just fine.
most effecient way to clean an axle The Blu Yak Modified Tech Discussion 16 December 30th, 2005 18:52
'97 XJ-Need 2 Foglamp Housings w/o Rust RAVC1 Wanted: Private Party Only 6 November 4th, 2004 07:28
Tail Light housings UNDER CONSTRUCTION Modified Tech Discussion 1 October 18th, 2004 12:09
Degrease engine Cherokee91Red OEM Tech Discussion 9 July 6th, 2004 14:25
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
