Old August 11th, 2017, 13:22
jeeptec's Avatar
jeeptec jeeptec is offline
Weak springs.
Ok here I go I was out on one of my local forrest roads going towards the trails. Been on this road many a time. Went through a couple dips like I have been before. I here a bottom out metal sound. I found my steering linkage bottom out on my track bar bracket. I'm running high steer on the left side and have at 6 plus inches of clearance. When I first built my XJ I did it short drop brackets Synergy 4.5 universal springs.( 4.5 on a JK. 3-3.5 on XJ) with 1 3/4 spacers gave me about 4 3/4 lift. No bottoming out. I upgraded to a core4x4 long arms. I installed Synergy universal 6.0 springs.(6.0 JK. 4.5 +XJ) the ride is not as smooth. Front end just seems to compress way too much. I'm running Bilstien 5150 shocks for 5 inch lift.caster is 6.5 camber -.5 toes about 1/16 toe in.
AW4 Weak Reverse GSequoia OEM Tech Discussion 11 October 19th, 2009 13:18
Weak coil? mattbred OEM Tech Discussion 4 June 30th, 2008 03:20
weak RyanM Jeep Picture Showcase 4 February 10th, 2008 20:31
Weak Starts uvaldetxj OEM Tech Discussion 5 January 19th, 2006 09:34
Dampers, weak springs, and overloads XJ Dreamin' OEM Tech Discussion 4 March 31st, 2004 22:37
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
