Old August 8th, 2017, 19:18
ehall's Avatar
ehall ehall is offline
Re: Which axles would you use?
I would build the JK Rubi axles if you already have them
my '91 beater rebuild
Old August 9th, 2017, 19:27
themauler's Avatar
themauler themauler is offline
I know this is going to start a dumpster fire but why not sell your JK axles buy someone's built 1 ton axles. You are located in WV so you know that you can't crawl everything. I guess you can develop skills not breaking stock jeep axles or picking lines you won't drag diffs on.
That's my thought and your options will be much greater with 8 lugs and only become vulnerable on tires over 40"
Old August 10th, 2017, 07:11
jonb8's Avatar
jonb8 jonb8 is offline
Been out of town at coaching classes... Thanks for all the input, WV has state inspection so tons are out of the question, way to wide. JK axles on stock offset wheels and 35 12.50's are 1/4 in narrower then stock xj axles on 4in offset wheels and 35 12.50's. It'll work but I have to stay on stock offset JK wheels...I don't like that. I'm not going over a 35 in tire, if I need to wheel hard I'll take the truggy but I'm trying to get out of the truck and trailer life and go back to driving to the trail...
Old August 10th, 2017, 12:24
themauler's Avatar
In that case just put ARBs and chromo axle shafts in the axles you have now. Maybe bump up to 4.88s. It sounds like you'll make the right decision.
Warning two people from our club in NC came home from Moab with broken spartan lockers on 35s.
Old August 10th, 2017, 14:49
Vanimal's Avatar
Vanimal Vanimal is offline
My opinion would be stay on 33's and stockish axles (no rcv's, full case locker and cheap alloys at best), jk d44's if going to 35's or 37's with a conservative pedal, or go tons if you are ok with not driving the thing on the street very often and dont care if you roll it.
If i had to choose, i'd stay on 33's with stock axles, which is what i went back to after 37's and tons.
IMO, wheeling is only fun if you have a challenge and you make it off the trail without destroying your rig. The bigger you get, the harder it is to be challenged without the high probability of severe body damage. If you want the challenge of the gnarliest trails, build a buggy and buy a tow rig. If you want to drive across the country, wheel, and drive home, stay where you're at and drive accordingly.
Originally Posted by GSequoia View Post
I always remember to brace myself before doing moderately tight work and get off when really cranking.
Old August 10th, 2017, 15:14
jonb8's Avatar
Yea I've gone big then back the other way, I went through Lions Den in under 6 minutes this spring. Didn't spin a tire or back up, now doing the Rubicon trail in all but stock xj with 35's and a open front end...LOL That was fun...... I did make Crawl Magazine this month in my truggy, great time......
Old September 20th, 2017, 21:24
4wheelspulling's Avatar
4wheelspulling 4wheelspulling is offline
Even though this is an old post, thought I would weigh in. I would sell the JK axles, and put that money into the d30 you have, and build up a junkyard Ford 8.8. 4.88 gears, good spicer u-joints, chrome moly axles and be done. If you get the right Ford 8.8 you get 31 spline shafts and disk brakes too! This is the route I took, even going over kill for my tire size. My build is more of a expedition build. I drive the XJ to my wheeling destination. I am also running small tires! 235/75/15s. I went with new gears, air lockers and chrome moly axles, good spicer u-joints with lock rings. No truss but would like too for the front axle and have the Cs gusseted. Would like to know what you ended up doing with your build?
Old September 21st, 2017, 07:55
burntkat burntkat is offline
NAXJA Member #1145
The more I look into it, the more I think I'm just going to do this to my son's XJ for the front axle:
https://www.youtube.com/watch?v=U6N9zCDyWUs&t=418s
He's only running 31s at present, and won't be doing a lot of wheeling. Certainly nothing hardcore, as this is his only vehicle. But by all means strengthen what he's got. For a couple hundred bucks and some time under the welding hood with him (teaching him a new skill) it's money well spent.
Might never be able to get the money out of it if I sell it- I don't care. Time in service getting him dependably to/from work and school does a lot for that, in my mind.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old November 1st, 2017, 05:20
jonb8's Avatar
After alot of back and forth I ended up going with the JK axles, It came down to the electric lockers. I hate the lunchbox locker in the rear of the xj... Always making alot of noise and scrubbing....That means buying two selectable lockers and having them setup... I've went with the Artec JK to TJ swap truss in the front and standard rear truss. I bought 9 used JK hardrock wheels for the jeep and teardrop and 35/12.50 17 BFG KM2"s. Gonna start the swap in a few weeks. Still need to work out trackbar and steering...
Old November 1st, 2017, 05:30
jonb8's Avatar
Originally Posted by old_man View Post
D30's on rocks with 33's are marginal at best. When you lock it, it gets worse. I got to the point where I could change out a drivers side shaft in less than 15 minutes. Even with the D44 upgrade from a 88 Ford Truck, I still have replace a couple of shafts and I drive very conservatively.
Like your teardrop. Where did you get it? I designed and built a very similar one from scratch.
Sorry old man, I just saw this. I also built mine. I pulled a popup for years but got tired of the setup time and clearance issues. I tried to comment on your build but I couldn't. Probably because I'm not a paying member, I'll have to get on the ball and become a member.
Old November 1st, 2017, 09:34
NAXJA Member #1145
Man that is a cool trailer!
This build is about to get good as well.
Old November 1st, 2017, 17:12
sinat01's Avatar
sinat01 sinat01 is offline
Go tons, either make steel flares to cover, or buy em. one of the guys I know has an XJ on tons and 39.5" swampers. all he has to do is make his front steel flares and it would pass inspection. or build the JK axles and run em, about the same width, tons would be heavier tho.
RCV ultimate dana axles vs Yukon/Superior axles HavvkXJ Modified Tech Discussion 25 March 21st, 2011 10:15
High-strength 29-spline 8.25 Axles; D30 ChroMo Axles XpedientJ Wanted: Private Party Only 2 February 6th, 2007 08:01
axles axles axles: New York xjrugger For Sale: Private Party Only. XJ ITEMS ONLY 3 March 2nd, 2005 07:51
width of xj axles vs. cj axles atowley Modified Tech Discussion 0 June 22nd, 2003 20:15
