Old August 8th, 2017, 11:24
burntkat burntkat is offline
NAXJA Member #1145
Re: Looking for a winch
Originally Posted by Green XJ Jeep View Post
Tow straps are much longer than a tree saver. Ideally you do not want to wrap a strap all the way around a tree or several times around a tree . The twisting motion of the strap as it tightens up will destroy the cambium layer of the tree
I think sliding is more a concern, but that's a good point I hadn't thought about. Good to know, I will add a few tree savers to my collection.
BTW- HF has straps and tree savers. Yes, it's HF, and so obviously crap, yadayadayada .. but it probably comes out of the same factory, and it's hard to screw up a strap. I've done some pretty good pulls with mine and have no issues with them.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old August 8th, 2017, 11:27
NAXJA Member #1145
Originally Posted by volumeknob View Post
I got ya and would run both to be honest. Wired remote and switch inside. I have everything to do the one inside, so it'll cost me some time but that's it.
I cut off a section of electrical cable (extension cord) and used that to run quick and easy to the winch solenoid pack, all in one jacket. Worked quick and easy.
Old August 8th, 2017, 11:29
NAXJA Member #1145
Just need some shackles, thinking about going with the rope kind but what do you guys like?
What is a "rope kind" of shackle?
I'm honestly asking, not sure what you mean. Do you mean a bow shackle??
Old August 8th, 2017, 15:26
volumeknob volumeknob is offline
They're a rope style instead of metal, less lethal if a break occurs. Look like this: http://www.unsealed4x4.com.au/gator-jaw-soft-shackles/
They seem to be legit, just kind pricey for what it compares to in forged steel bow shackles.
Old August 8th, 2017, 19:56
trippled trippled is offline
For a bumper mount a steel shackle is fine. I think the real benefit would be if you had to connect 2 straps together or hooking to a tree saver, you no longer have a large projectile if something let's go. I plan on buying some for that reason alone.
Old August 9th, 2017, 08:06
NAXJA Member #1145
Very interesting product. Thanks for the info!
Old August 9th, 2017, 11:29
So what 2" hitch winch mount do you guys like or have experience with? I've decided to go this route so it can be used on the front or the back and can be taken off and out of the weather when I'm not wheeling.
Old August 9th, 2017, 12:18
lawagoneer lawagoneer is offline
First great buy on the Warn, you will not be disappointed. My Warn is close to 30 years old, I got it not working but only needed 1 selonoid to fix it. Warn backs up its winches better than anyone I know of. Mine is mounted to my front bumper as it was on the vehicle I got it off. Never babied, worked hard and still runs like new. That being said I understand the attraction to the receiver mounts if for theft prevention if nothing else. It's hard to steal a winch if it's not on the vehicle. Are you going to install a front receiver as well?
Old August 9th, 2017, 13:07
Right, theft and weather are major things I considered just because I like to take care of my stuff but having the option of running it front or back is pretty nifty. I have a bumper that came with my 98 that has a 2" receiver welded into it already. There's a Reese receiver hitch out back with the steel stocker less the caps. Once I get the front bumper on and figure out my steering problem(s) I'll post some pics.
Old August 9th, 2017, 13:20
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
I ran a drawtight i picked up from etrailer for 113 delivered.
Worked great tucked up under the bumper nice.
Old August 9th, 2017, 19:41
Sounds like a great setup. I too thought about theft and replaced one of my winch bolts with a Factor 55 security bolt. Nothing will stop a determined theif but it would make the opportunist look for something easier. Pics when all is done would be great.
Old August 10th, 2017, 07:13
NAXJA Member #1145
I usually just weld a piece of angle over the bolts so that the thief would have to have a grinder as well. They'd have to remove the bumper first.
come down to it, a hammer and a screwdriver will get the whole darn vehicle if they really want it. With this in mind (and weather) I am designing the bumper for my S10 to have the winch covered but accessible with an access plate. Out of sight, out of mind.
Old August 10th, 2017, 07:43
NAXJA Member 4950
Boostwerks needs to get busy and get that comp mount out. Behind the stock bumper with the fairlead tucked behind a license plate is pretty much "out of site out of mind".
Old August 10th, 2017, 10:09
I'm actually seriously considering their steering brace without the winch mount you're speaking of. Seems like the best solution on the market, just pricey. I could probably fabricate one but after time and materials, it's probably worth just buying so it's right.
Old August 10th, 2017, 10:42
ehall's Avatar
ehall ehall is offline
hitch mounts rated for 5000 lb? not enough for me. I have an ATV winch on a tray for my dad's F150 to drag trees around (not lift them), way under spec for holding my XJ on a mountain
my '91 beater rebuild
WARN WINCH & AIR COMPRESSOR PowerPlant Dual Force HP 9500LB Winch NEW RWKHausSupply Vendor's Specials 0 June 13th, 2013 11:07
my newest project: cut up old bumper, added winch, in-cab winch control, etc EricsXJ Jeep Picture Showcase 13 April 11th, 2007 22:36
M.O.R.E Front Winch Bumper + Ramsey REP8.5E Winch + Safari Snorkel mikeswrangler For Sale: Private Party Only. XJ ITEMS ONLY 1 July 24th, 2006 21:28
Mounting the mobile solenoid winch pack...underhood or on top of winch??? Big Red Modified Tech Discussion 19 July 4th, 2006 08:43
winch, 8.25 locker, cage, winch bumper or front hitch olivedrabcj7 Wanted: Private Party Only 0 May 8th, 2005 14:22
