Old June 20th, 2017, 16:35
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Re: 4.6 build starts today!!!
I did have to massage the heat shield to clear the Banks header, but that wasn't to bad because I hadn't installed the motor yet!
What is this heat-shield you speak of?
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old June 20th, 2017, 17:21
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Maybe small skirt of mani gasket?
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 20th, 2017, 17:56
RCP Phx RCP Phx is online now
The driver side mount has a riveted heat shield. I've also purchased the Design Engineering fuel rail kit and will do anything else to control/reduce the temps.
Old June 21st, 2017, 07:56
Redsnake Redsnake is offline
Great looking build!! I ditched that heat shield when I replaced my Pre-Cat's and added the Banks-like headers to my '01 XJ. Wish I could've kept it but since doing the install with the engine still in my rig I simply couldn't get access to all the bolts w/that aluminum shield there. Thankfully I haven't had any heat related issues since the install.
Old June 23rd, 2017, 13:46
OOPS!!
Gotta slide the motor back out, I forgot to put the top trans/engine shield in!
Old June 23rd, 2017, 16:02
That wasn't to bad. I was able to separate the eng/trans a few inches a "beat" the shield in between the flexplate and up/over the shuffle pins. Back tomorrow to pickup where I should have been today!
Old June 23rd, 2017, 17:33
We'll besides finishing up the bottom side, I got the int/exh loosely mocked up and can tell you that the DE manifold heat shield is a joke so I'll re-address that area later.
Old June 25th, 2017, 19:15
We'll I got a few things done this weekend:
Starter is in
Oil dipstick, filter adapter, and oil filter on
Alternator, A/C comp, and fan hub on
Header, intake, and fuel rail w/ heat shield on
Throttle body on
Spent some time on "hi-flowing" my t-stat housing
and finally got to my lifter pre-load, it came in at .080" so I've ordered some .030" shims!
Old June 27th, 2017, 09:33
Nealio240z's Avatar
Nealio240z Nealio240z is offline
I will be watching this thread closely. I plan to do a very similar build for my 89' with a ax-15.
Good work!
Old June 28th, 2017, 10:12
Slimer Slimer is offline
When doing a higher-end build like this do you use a torque-plate when boring the cylinder? Just curious.
Old June 28th, 2017, 13:16
typerr typerr is offline
My understanding is Russ uses a torque plate if he does your machine work. I am also watching this thread. If I do a stroker I will have Russ do the machine work, parts and prep as he is local to me.
PCP Phx, what kind of power/tq are you estimating from this build?
Old June 28th, 2017, 21:09
I never even asked him based on his reputation! My shims came in today, and I missed my calc, the new depression resulted in .035"(I calculated .032"). I never had any numbers in HP/TQ that I was shooting for other than better towing and cooling (never had a issue off-road since I have 4.10's and a 4:1 transfer case).My hopes are since this isn't a Russ "crate" motor that I can get similar performance. I have a appointment tomorrow morning for a full 2-1/2" exhaust with a new cat and muffler vs just doing a adapter/transition pipe!
Old June 30th, 2017, 16:17
A little update.....first I spoke w/o thinking, Russ sent me a E-mail to remind me of the fact that he didn't do the block work! It was done by my local machinist that always uses a torque plate.
Yesterday was spent finishing up all the loose ends after getting it back from the muffler shop. They did a great job!
I made my own vs of a cold intake box using stock components.
Today after priming the pump and setting the cam positioner I was able to fire it up. It hit on about a 1/4 turn of the crank. It sounds good with all major gauges reading excellent. It never got hot but my CEL came on immediately with several codes. I attribute all these with going to 2000-2500rpm (for 25 minutes immediately) with no chance to learn! I have reset the codes and will do a minor driving run after everything has cooled down!
BTW : my VHT header paint was gone in about 60 seconds.
Old June 30th, 2017, 17:44
ehall's Avatar
ehall ehall is offline
looks good!
my '91 beater rebuild
Old June 30th, 2017, 18:03
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
so when is the test drive?
Winter on the Rocks starts today SandySteve InterMountain Staging Area 0 January 19th, 2017 10:56
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Jeepers Jamboree starts today..woo hoo rocknxj Sierra Chapter 22 August 2nd, 2008 19:53
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 14 December 7th, 2007 08:03
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 4 November 10th, 2007 09:00
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
