Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old October 2nd, 2016, 23:40
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
Re: Steering upgarde
What is that 44 out of? If it's a TJ then you can use stock, or stock replacement parts. The confusion comes because no XJ came with a 44 front and most swaps are from a different vehicle with different steering dimensions making none of the direct fit stuff usable. If you don't want to drill your options are limited since very few larger/stronger TREs fit the stock taper.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old October 3rd, 2016, 05:30
RCP Phx RCP Phx is offline
.....in North America, otherwise yes the XJ was available with a front D44!
Old October 3rd, 2016, 05:47
BasselAlawar BasselAlawar is offline
My both diffs are G2 AXLES DANA 44 TJ RUBICON SWAP. THE setup is bolts on! and thats why is dont want drilling!
Old October 3rd, 2016, 05:49
I am thinking of the y linkage since as I read is better while dealing with death wobbles! So mainly synergy and currie maintian the y link geometry while they have upgraded HD kits
Old October 4th, 2016, 09:21
mcguyver_xj's Avatar
mcguyver_xj mcguyver_xj is offline
Steering upgarde
New steering isn't always the fix for death wobble if you even have death wobble
Old October 4th, 2016, 10:30
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
15 years i have been XJing and while people claim that all the time, nobody has ever managed to produce a single one.
'i have seen one'
'a guy has one in the garage'
'i have one in the garage for later'
'i used to have one'
'there was one on ebay'
but yet i have never seen a photo of a single one. convinced its a myth.
Old October 4th, 2016, 10:42
Steering upgarde
I don't have death wobble but I actually worry if changing the steering geometry will cause death wobble to happen!
Old October 4th, 2016, 19:58
Steering upgarde
Makes more sense
Old August 10th, 2017, 09:46
NOutdoors92's Avatar
NOutdoors92 NOutdoors92 is offline
Hello to all,
First time posting here but I've been around for awhile now. Read as many threads as I can but can't seem to find the one I'm looking for again. Recently purchased a 95 xj. 3" lift on 31s. By the looks of it that's all that's been done mechanically. Looking for a 1 ton OTK kit but they all seem to be the same thing just different makers. Seen a post about someone doing a diy kit. Was wondering if anyone has experience with this route and what cost was like. Cost is not an issue at the moment but I purchased this to tinker with and improve my skills. So I would prefer a diy kit if price is less then a JRC, Rusty's (have heard more bad then good), etc, kits. Right now it's still a DD/weekend warrior. As long as it can make a 3 hr freeway trip once a month is the extent of the DD. Rest is around town, dirt road driving. Right now it just does mild trails and crawling. Blue green type stuff. 5" lift with 35s are on the upgrade list as well. Building to be a crawler. Pics soon if needed. Can't figure out how to add em on my phone.
Old August 10th, 2017, 09:48
cal's Avatar
cal cal is offline
If I were going to buy a 1 ton kit right now, it would be this one:
http://www.stinkyfab.com/steering-co...-xj-tj-zj.html
Not only does it use 7075 aluminum links, but Moog joints, and he offers lifetime warranty on the links and the joints.
Old August 10th, 2017, 10:17
What warrants the extra $250 for the OTK track bar kit? Is that something that can be fabbed myself? Or sourced cheaper? I couldn't find a parts list to see what extra it has.
Old August 10th, 2017, 10:20
cal's Avatar
cal cal is offline
Its an aluminium trackbar with ends, a weld on axle bracket and a bolt on frame bracket.
250 is a steal.
Old August 11th, 2017, 09:06
kcox506's Avatar
kcox506 kcox506 is offline
This is a pretty simple approach to a lot stronger steering. Its Under The Knuckle and uses larger than 1 Ton rod ends. There's an OTK version as well All you need to do is just ream the knuckles and pitman arm like any other 1 ton kit and you're golden.
No tie rod roll, no clearance issues, its straight beefy steering that seems like a good option for your case.
UTK
https://www.ironman4x4fab.com/produc...uckle-steering
OTK
Ironman4x4fab Marketing Manager
2000 XJ ~4.5" '06 4.0
LP44 w/Rubi Air Locker & 8.8 ARB
231 w/ beefy stuff
Old August 11th, 2017, 10:09
burntkat burntkat is offline
NAXJA Member #1145
'i have seen one'
17 years here, and x2
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Next: finish front, build rear bumpers, Dana 44's front and rear.
-94 ZJ: Budget boost, 31's. The wife's mall crawler. She's gotten inchitis over my S10 though...
-97 XJ: Son's DD. Mild mods for the new driver.
Steering Issue - choppy steering wheel return fishinpolejoe OEM Tech Discussion 10 July 2nd, 2015 12:09
Steering Shaft Brace? Looking for ideas for my steering problem. andrew2516 Modified Tech Discussion 37 March 12th, 2013 08:48
Steering debate between: wj steering, currie, rustys bigdelt69 Modified Tech Discussion 53 December 1st, 2009 20:38
89 XJ Steering Gear Box, PS Pump, and Steering Shaft For Sale waxer SoCal For Sale 4 June 22nd, 2008 12:34
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 12:38
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
