Old September 18th, 2016, 05:57
BasselAlawar BasselAlawar is offline
Steering upgarde
Greetings,
I am in research phase of steering upgrade, saw synergy kit that it direct bolts on and the teraflex kit that requires some modifications.
Could you kindly help with proper decision! thank you!
Old September 20th, 2016, 23:49
StinkyFab's Avatar
StinkyFab StinkyFab is offline
NAXJA Supporting Vendor
Re: Steering upgarde
We just released our 1-Ton kit as well. What are you wanting to accomplish, and what are your needs? There are a bunch of kits out there, some better in some areas, some better in others. What are your capabilities as far as doing the install yourself? It's easier to help you with a decision if we know what you're working with and what you're looking for.
Dallas Ashley
WWW.STINKYFAB.COM
Motor Mounts, Fabrication tools, and Custom stuff for your Jeep!
Old September 26th, 2016, 06:33
Hello!
I am basically searching a better steering kit with no drilling requirements, i don't care for high steer, that is why I found the synergy kit suitable!
My current setup is Dana 44 with AGR rock ram, hydro steer kit. Kindly assist!
Old September 27th, 2016, 21:31
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
Steering upgarde
Pictures of your current setup would be very helpful
Also which synergy kit were you looking at
Old October 1st, 2016, 05:29
http://www.synergymfg.com/Synergy-Je...t-p-30968.html
This is the synergy kit I am looking ahead to install.
Old October 1st, 2016, 08:08
RCP Phx RCP Phx is offline
I would stay away from any of the "T" set-ups! For that money you could go Currie.
Old October 1st, 2016, 08:30
Steering upgarde
If this is your current setup than no that kit will not work for you. What you listed above is a heavily modified setup. The synergy and teraflex kits are made to work with a stock setup and stock axle. You have neither of those.
What seems to be the problem with your current setup?
Old October 1st, 2016, 11:24
Steering upgarde
No problems I just want a 1 ton setup. The current setup looks skinny with the mods surrounding!
Old October 1st, 2016, 11:25
Steering upgarde
Old October 1st, 2016, 11:53
They're not small, did you read the specs?
http://currieenterprises5.reachlocal.net/CE-9701
Old October 1st, 2016, 12:03
Steering upgarde
I meant my current setup, not the currie! Are the TREs changeable in currie kit?
Old October 2nd, 2016, 00:54
Steering upgarde
The synergy kit and the currie kit have the same geometry and both are bolts on!
Old October 2nd, 2016, 07:51
trippled trippled is offline
Again, your setup is not stock so none of these kits will work for you.
Old October 2nd, 2016, 11:33
techno1154's Avatar
techno1154 techno1154 is offline
Post a picture of the steering setup looking from the front of the XJ showing all the linkages. Someone will be able to recognize the parts and make recommendations.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 2nd, 2016, 11:34
DansGreyMj's Avatar
DansGreyMj DansGreyMj is offline
From the picture he posted it looks like he is currently running stock steering.
Sent from my SM-G930T using Tapatalk
1987 MJ 4.0 5 speed, Charcoal Metallic w/ black interior. HP Dana 44, custom rear 60, zips, 5.13s and 35s.
Steering Issue - choppy steering wheel return fishinpolejoe OEM Tech Discussion 10 July 2nd, 2015 13:09
Steering Shaft Brace? Looking for ideas for my steering problem. andrew2516 Modified Tech Discussion 37 March 12th, 2013 09:48
Steering debate between: wj steering, currie, rustys bigdelt69 Modified Tech Discussion 53 December 1st, 2009 21:38
89 XJ Steering Gear Box, PS Pump, and Steering Shaft For Sale waxer SoCal For Sale 4 June 22nd, 2008 13:34
Thread size/pitch of power steering pump/steering gear inlet/outlet? hotrod22 OEM Tech Discussion 7 January 16th, 2006 13:38
