Cottontail
Three-De Off-Road
- Nashville, TN
I have the FSM for my 1985 XJ and the brake booster swap looks to be pretty straight forward. It appears that I can detach the master cylinder from the brake booster, without unhooking the brake lines that are attached to the MC. Then just unhook the booster from the pedal and fire wall, then do it all in reverse with the new booster. But, here are some specific questions not covered in the FSM...
Do I or do I not need to empty the MC of fluid to do the swap?
Will I loose brake fluid when I detach the MC from the booster?
Will I need to bleed the brakes after the new booster is on and the MC is reattached?
There is no fluid inisde the booster, correct?
Autozone quoted me $78 for a new booster. Am I just as well off using a boneyard part for cheaper?
Anything I should look out for in replacing the booster?
Thanks for any and all information that will assist me in this project.
