Old July 16th, 2012, 06:58
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
Re: [Tech Writeup] Replacing the seals on your Dana 30
the seal sits behind the bearing, to replace it the carrier needs to come out.
Old June 10th, 2014, 21:09
88trailcrawler's Avatar
88trailcrawler 88trailcrawler is offline
Reviving this great write up thread.
The XJ just returned from a road trip with a front wheel squeak and a puddle of gear oil on the lower knuckle.
My ONLY concern is pulling and replacing the carrier. I have ected electric lockers in there. Does this still all come out and go back in in one piece without and issues?
Old June 10th, 2014, 21:16
Dead man walking
I've never messed with e-lockers but the 30 doesn't need to be adjusted when r&ring the carrier... it should be fine. just make sure the bearings races and bearing caps stay on the sides they came off of.
Old June 10th, 2014, 22:12
Sweet thanks Grimm.
Last question is how to determine seal part numbers. Its an '88. But has a HP non disco D30 swapped in. And any upgraded or preferred seals to use?
Old June 10th, 2014, 22:17
Dead man walking
just use the ones i threw the number out for in the begining of this thread, stick with national or timken brand and you should be ok.
Old October 10th, 2014, 18:19
CrashtNBurnt's Avatar
CrashtNBurnt CrashtNBurnt is offline
So.... That red o-ring or silicone between the seal and bearing on my XJ is gone! Both sides look like they have been cut out. WTF.... I love finding these things that have been done to my XJ. My question is what should I do now. I've got everything torn a part and ready to go back together.
Please help.
Old October 10th, 2014, 18:21
Dead man walking
you'll be fine, if its not leaking around the edges where the tube is pressed into the center section now it won't when you're done replacing the seals.
Old October 11th, 2014, 08:38
Thanks Grimm! This has been a life saver for me! Awesome post! Now I gotta put the jeep back together and get to the mud drags!
Old February 9th, 2015, 09:05
xjrick94's Avatar
xjrick94 xjrick94 is offline
Great write up Mike. Assuming that I can track down a driver side steering knuckle on time I'm going to tear into it and replace the seal this weekend.
Old February 9th, 2015, 09:18
Dead man walking
anyone have the 97+ dash removal writeup? (replacing evaporator) theksmith OEM Tech Discussion 6 August 31st, 2007 11:11
replacing valve stem seals justright92xj OEM Tech Discussion 5 April 20th, 2006 17:07
Dana 44 Seals SPSERG OEM Tech Discussion 9 June 26th, 2005 17:50
replacing d30 seals Kejtar OEM Tech Discussion 9 May 11th, 2005 07:31
SubFrame Tech Writeup JeepFreak21 Modified Tech Discussion 16 May 25th, 2004 13:50
