Old June 20th, 2007, 21:27
srimes's Avatar
srimes srimes is offline
Use a jeep as a tractor?
I gonna move soon and hope to end up with some land. I've got a little MTD lawn tractor that a friend gave me, but a larger one won't be in the budget for a while. So I was thinking of getting one of those powered tow-behind rough cut mowers for clearing a field with my xj. I like the idea of mowing the lawn with a stereo and air conditioning. Anyone ever try this? Sould like it'll work?
Also, I saw that someone makes a trailer for ATVs that has a 3 point hitch, with a winch for raising the arms. Could I use this and a box blade with the jeep for driveway maintenance and leveling fields if I get the notion?
I think I'd put in a hand throttle to make the tasks easier. Any other modifications to think about?
Old June 20th, 2007, 23:03
ColoradoJeepXJ ColoradoJeepXJ is offline
I have not Confirmed, or I used a BAD email Addy
Re: Use a jeep as a tractor?
You can do anything with a XJ.
Old June 21st, 2007, 01:01
8Mud's Avatar
8Mud 8Mud is offline
I've done both. No major problems, long stretches in low range and my temperatures did creep up though.
I made a square drag, angle iron. a section of chain link fence and a few cement parking lot stops. Worked like a charm. Cut most of the weeds and left much of the grass.
Also made a drag from angle iron (inverted V) and again some weight, to knock the crown off of access roads.
Cutters gave me a bit more of a problem, when they jam it can cause a heck of a jar. Wear your seatbelt. I always seemed to find a chunk of steel fence post or an old tree root, that would stop me in my tracks.
Old June 21st, 2007, 06:13
jpk's Avatar
jpk jpk is offline
The old post war CJ's had a rear PTO to which many farming impliments could be attached. I don't see why an XJ couldn't be used if the right equipment can be connected. The XJ doesn't have a PTO but I would think it's strudy enough to do anything the little old CJ could do.
Old June 21st, 2007, 06:24
SwissArmyJeep's Avatar
SwissArmyJeep SwissArmyJeep is offline
Hell Yeah! My grandfather used to use an old CJ5 to plow his fields. Tell me that don't leave an impression on a young Jeeper to be. He had a bad leg, and the CJ was easier for him to use than a tractor. Your XJ should perform just fine. Just be prepaired for the looks you will get from the bystanders
Old June 21st, 2007, 06:36
RichP's Avatar
RichP RichP is offline
Also make sure that rear hitch is using ALL the mounting points on the frame rails and that the inserts are in good condition. There are some farmers up here that use CJ's and a few YJ's for field work, never seen it done with a XJ or a ZJ though
Towing gang mowers should not be an issue though I would think they will need their own engines unless you can figure out a PTO of some sort unless the turning of the wheels will operate the blades.
Sounds cool but not cool enough that I woul want more than the septic tank, drainage field and the 4ft border around the road side of my corner property, the rest is all woods.
Old June 21st, 2007, 07:50
ren's Avatar
ren ren is offline
Just don't try to pull good sized stumps with it. I will post a pic. later to explain why this was not a good idea. Thanks be that it wasn't MY Jeep, but, now, I get to fix it. Stupid kid. And yeah, the hitch was mounted using all of the factory holes.
Old June 21st, 2007, 08:11
Matthew Currie's Avatar
Matthew Currie Matthew Currie is offline
NAXJA Member #760
The pull behind mower should work just fine. I'd be a little warier of a weight bearing hitch like a 3-point hitch on an XJ, partly because the vehicle is so light, You might have traction problems unless you counterweight the front end. Unfortunately there's no really convenient way to fit a PTO either. Back in the good old days, the Dana transfer cases and many of the transmissions had a provision for a PTO. and you could buy the kit with shafts and bearings to send it forward or back. Nowadays, if you wanted to outfit an XJ for PTO, I think a hydraulic pump and motor would work better.
I've thought seriously of trying to set up my rusted but strong running 95 with a big snowblower. Skid steer loaders often use hydraulically operated accessories, and I figure a pump in place of the AC compressor could open up a lot of possibilities.
Old June 21st, 2007, 08:14
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
A Jeep is nothing more than a tractor, designed to drive comfortably at 55 mph......
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old June 21st, 2007, 08:42
ren's Avatar
ren ren is offline
Hell, skid steers are nothing but a hydralic( yea, yea spelling) operated accessory
3 Pt. tractor/long arms LandCruizzer Modified Tech Discussion 9 February 23rd, 2006 20:31
Tractor Paint davidt Modified Tech Discussion 5 July 8th, 2005 23:13
Tractor Supply OMG diabloxj Non-Tech / Off Topic 10 February 22nd, 2005 23:39
Craftsman lawn tractor snow plow ? CaptTrev Non-Tech / Off Topic 14 January 26th, 2005 05:02
Tractor Arms XJeeper05 Modified Tech Discussion 6 May 18th, 2004 13:51
