Old January 11th, 2008, 14:24
terryd's Avatar
terryd terryd is offline
Some light duty mods for a camping XJ
Here's some shots of some stuff I've done to the Jeep in the last 6 months or so.
I trimmed the air dam off the front bumper and cleaned up the license plate holder a little bit.
My new Bastard Packs. They are made with longer (long bed) S-10 leaves under a Cherokee main with poly bushings installed. The front of the 2nd leaf is under the main eye and the rear of it is much closer to the shackle eye than the old set. Hope these last longer.
I had stretched the YJ lines I had on it, so I decided to use some C-1500 lines like I had seen elsewhere. I had to make a bracket for the frame end and wrapped it in PV tubing to keep the shocks from rubbing them.
Also, I'm carrying my spare tire laying flat in the cargo area. I was a little leery of the stock tie-downs that are riveted to the floor without any extra support. I bought these at Tractor Supply for $1.29 ea. Rated at 1200LBS.
Drilled the old ones out and then drilled the extra hole in the floor to mount these.
Also while there, I was wanting to move my High-Lift inside off the roof rack. Matt came up with this idea.
I think looks pretty good back there. I feel a little better about having my little girl strapped in back there now that the spare isn't going to rip lose if something should happen.
Old January 11th, 2008, 15:34
97XJ Jeeper's Avatar
97XJ Jeeper 97XJ Jeeper is offline
Semper Fi
Re: Some light duty mods for a camping XJ
Looks good, gave me some ideas, nice car seat, I think i have the same one but on the other side.
Old January 11th, 2008, 15:40
terryd's Avatar
mines usually there, but had the old lady with me today, and the seats there so she could mind Alex and I could drive.
Old January 11th, 2008, 15:50
RyanM's Avatar
RyanM RyanM is offline
Ouch
Old January 11th, 2008, 16:15
terryd's Avatar
Originally Posted by RyanM
Ouch
Old January 11th, 2008, 16:32
RyanM's Avatar
leaf looks like it's gonna break and it's not flexed
Old January 11th, 2008, 16:55
terryd's Avatar
well, today was the first time I've wheeled that set of leaves. They looked like that the day I put them together, as did my last S-10 pack. The last set never broke, but the passenger side just wore out and bent (closer to the spring pad) and couldn't carry the jeep anymore. After this set is through, I'm going with a set of aftermarket springs instead of anymore BP's.
Old January 11th, 2008, 17:33
Shorty's Avatar
Shorty Shorty is offline
pssssst-- your tags expire in 20 days!
--Shorty
Old January 11th, 2008, 17:45
terryd's Avatar
woops...... I've got the new stickers some where..... hope the old lady hasn't thrown them away.
Old January 11th, 2008, 17:47
Slo-Sho's Avatar
Slo-Sho Slo-Sho is offline
May I ask why the stock spare location isn't suitable for you?
Old January 11th, 2008, 17:50
terryd's Avatar
With it in the stock location, I can't close the hatch w/ the back seat latched. Also, it hits the speaker bar if its sitting on the little bracket screwed to the floor. I'm wanting to make the brackets that Go-Jeep made to fit his 32 in the back of his XJ, but have not had the motivation to do so.
Heavy duty OME vs Medium Duty OME jdurbach Modified Tech Discussion 10 August 9th, 2007 15:25
Never been camping before, what do I need? hotrod22 Non-Tech / Off Topic 29 May 21st, 2007 15:28
Camping at BB olympic4x4tech SoCal Chapter 8 May 5th, 2006 14:22
AW4/AX15 wiring mods and CE Light Kejtar Modified Tech Discussion 4 August 9th, 2004 20:56
Light duty farm equipment....recommendations?? Safari Ary Non-Tech / Off Topic 26 October 28th, 2003 17:00
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
