Old August 29th, 2017, 07:19
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Project Unicorn - a light duty trail rig
Originally Posted by 1990JEEPXJ View Post
That metal piece for the balancer install looks like a metal sleeve from RE lower control arm bushings. I have a few laying around that I find to be quite useful
Rather plausible. I've had a number of RE arms over the years.
Old August 29th, 2017, 10:33
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
I'm not saying it's hot, but two hobbits just threw a ring into my yard.
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old August 29th, 2017, 10:40
Heavyopp Heavyopp is offline
Glad you guys have the heat on that side of the country -- I'm in NJ -- It was in the upper 50's low 60's last night and been on the cool side all summer
Old September 4th, 2017, 20:43
cal's Avatar
cal cal is offline
Cooled off a bit today so got more done.
Slammed the water pump in. Interestingly, this Mopar Performance pump is *identical* to the Gates pump we use on 4643. Guess I won't spend money on this again..
While I was working on something, my elbow brushed the AC pulley and spun it. It made shockingly bad noises. Its been engaging just fine, but something is not right.
A new Mopar clutch cost about the same as a rebuilt compressor, but this way i don't have to break and recharge the system, and I figure my 100K miles compressor is probably in better shape than any rebuilt unit.
Remove the nut over the clutch.
Gently pry the clutch up with a screwdriver or two.
Under the clutch nut is a shim, don't lose track of it.
Remove the C-Clip holding the clutch in.
Two arm puller to pull the clutch pully off. Comes off pretty easy.
Another c-clip to remove the stator.
Unbolt the wiring harness. It also has the ground attached.
Unplug the harness behind the compressor.
All stripped down.
Old September 4th, 2017, 20:56
cal's Avatar
cal cal is offline
Slide the new stator on. There is a small dowel to clock it, watch that.
Reinstall the c-clip.
Bolt the wiring and ground back down. Replug plug in back.
Slide the new pulley in place.
Break a crappy autozone installation tool pressing the pulley back down.
Here's where it gets interesting. Remember this shim?
Jumper the clutch to engage it.
I forgot to take a picture measuring the distance between the clutch and pulley. I used a slide caliper but here they show using a feeler gauge. They want .4mm to .8mm, about .030". I got it on the 2nd attempt using a .020" shim.
Image stolen from google:
Once your spacing is right, throw the nut back on.
Turns out my old clutch was getting pretty shot.
Old September 4th, 2017, 21:07
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Fascinating.
I did not know the compressor could be serviced that way. Probably not something you want to do on the trail, but nice to know it can be done with a few mildly specialized tools.
Thank you for the details.
Old September 4th, 2017, 21:43
cal's Avatar
cal cal is offline
You could probably manage it with a couple of prybars and a hammer if you had to.
Old September 4th, 2017, 22:07
burntkat burntkat is offline
NAXJA Member #1145
Thanks for posting this. Driving my son's 97 has me spoiled, what with functional air conditioning. I'm looking to forklift the AC in my S10 in the next couple months.
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old September 5th, 2017, 06:24
cal's Avatar
cal cal is offline
Today we get to modify a Mopar 5191929AA radiator to have AC condenser mounts, and then figure out what I'm doing about a trans cooler before I start installing more stuff.
Old September 5th, 2017, 10:06
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
I've been using an ford Trans cooler out of an f250, they used the same ones in tons of vehicles. easily procured from a JY. fits well in front of the AC condenser.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old September 5th, 2017, 10:08
cal's Avatar
cal cal is offline
I have stacks of coolers.
Not sure which one I want to use, but it will be something out of inventory.
Not sure if I want to run it in front of the electric fan or the mechanical fan.
Not sure if I want to run it back through the radiator cooler on the way back to the trans or not - strong arguments to be made both ways.
Old September 5th, 2017, 11:49
Associate
I chose mechanical for the trans, electric for the P/S. my rationale was the trans is always being used, and should probably always be getting air pulled across the cooler.
the P/S really only needs to be cooled when its being worked, and in that case the E-fan is almost always running.
if you plan on your rig seeing a lot of colder weather, I would vote for plumbing it back through the rad.
if its going to stay in warmer climate, I don't see the point.
food for thought.
Old September 5th, 2017, 11:50
cal's Avatar
cal cal is offline
lol that may be your most ambiguous post ever.
ambiguous is italian for useless information right?
Old September 5th, 2017, 11:52
Associate
your douchebag is showing.
Old September 5th, 2017, 20:03
I used a BM 70273 recently on my XJ -- Didn't have the stock of coolers laying around -- Put it in front of the AC condenser on the mechanical fan side -- Fit just fine between the condenser and grill
I also did plumb it thru the radiator -- I'm in NJ and see plenty of cold weather -- trans output, to lower radiator, upper radiator to lower cooler, upper cooler back to trans -- Also plumbed it in stainless braided -6AN teflon hose and fittings
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 17:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 19:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 11:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 15:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 17:50
