front driveshaft question
JERSEY99XJ
NJ
when i replaced my engine i pulled the trans and transfer case with it. therefor i had to remove the driveshafts. when i put the new engine in both shafts were short. the rear i bolted in and it stretched back out so i figure the front is the same way. but i cant get it to work. does anyone knwo any easy to bolt the front shaft up? thanks
