coastie124
- Mobile,AL
I've posted elsewhere but I figured this would be the most helpful forum. Title says it all. This is going to be a true budget build. Starting off with a 1991 Black 4door Cherokee laredo with a 7" lift (i'm wondering if it isn't the 6.5 kit as rusty's doesn't offer a 7" as of right now). Dana 44 rear with limited slip. Dana 30 front with the vaccum disconnects. Automatic Tranny with the NP231 transfer case. The interior is pretty dirty but should clean up decent. It's got some cheapo sound system installed Notice the crappy looking sub box in the pix. It's a rusty's lift kit which includes:
• 2 - Front Coil Springs
• 2 - Rear Spring Packs
• Heavy Duty Adjustable Trac Bar with Frame Mount
• Upper Control Arms
• Lower Control Arms
• Stainless Steel Brake Line Extension Kit
• Front Sway Bar Disconnects JKS
Looks pretty heavy duty. And the springs are decent.
It's got some bald 33" BFG AT/KO's and by bald I mean the front ones you can see the belts.
The front window is cracked. The right hand mirror is broken. The front grill and cowling are cracked. The cowling is going to need some fiberglass repair work. And just the regular dents and dings associated with a 16 y/o vehicle in the south.
