themangeraaad
- Halifax, MA
Well, I searched and alot of the threads I came up with gave me the result I was expecting with a slightly different explaination of the problem. My brake pedal goes relatively far down and then catches and begins braking. Many threads said master cylinder.. which I thought could be my problem. I am not leaking at all. The difference I have is that all the threads said if pressure is applied, the pedal with gradually sink to the floor if the master cylinder is bad... I am getting nearly no braking till the pedal is quite far to the floor rather than a sinking pedal.. I had the brakes bled out properly and they worked great for quite a while, now in the past few days they seem to have become problematic all of a sudden. Any ideas other than master cylinder? or any possiblities or recomendations or whatnot?
