How good of a deal is this?
I'd consider buying it for my worst friend !!!
That kit should be deemed un-safe!
Can you guys tell me what's wrong with it? It looks much stronger than the stock components and the very jeep it would be bolted to
I tend to think some the jeep world strength requirements are sometimes over-stated
But I would legitimately like to know what you guys think is wrong.
I wouldn't be interested in it. I'd rather buy the much cheaper RC long arm upgrade if I was buying a radius arm setup like that.
I think a RC Long arm kit would be way better. The cross member on that kit isn't bolted onto the two outer pieces which would cause a lot of play (I know there is a cross piece but it uses bushings which is not a good idea in this application).
yep bushings in the cross member. shouldn't have movement there...
Besides taking a rigid structural cross-member and put "hinges" in the middle, the arm mounting points are to far apart. That's a sure sign of wasting bushings or tearing the axle mount off. In a perfect world they would located at the same point-in a "V".
Using bushings on a crossmember isn’t uncommon. Usually that means the stock trans mount is not used though. This kit doesn’t appear to be any sort of death trap but spending money on a known brand kit would probably be a wiser decision
