Sounds like the TCU/fuse/harness may not be functioning.
First, fluid condition, type, quantity all correct? We will A**ume yes as you have just flushed it, we are positive you used Dex III (or equivalent), and checked the level.
Second, we are going to A**ume that the throttle pressure cable is correctly adjusted, and that the TPS has been tested and is within specs.
Now, unplug the TCU and drive shifting manually. You should have 1st in 1-2; 3rd in 3; 4th in D; reverse, neutral, and park. If that is what you get, then the problem is electrical/electronic in nature.
Check the fuse in the PDC, should be a 10 amp--is it good?
