Old January 1st, 2018, 20:03
alek21 alek21 is offline
Bad grinding when starting engine.
2001 Jeep xj, 4.0l, aw4, np231 180k miles.
Just did a 4wd conversion on the jeep this weekend.originally had a 2wd automatic and I swapped in a 4wd aw4 with an np231 bolted to it. Got everything all bolted up and torqued down to specs and went to bump the motor and it is making a horrible grinding sound. Pulled the starter off and re-installed it to make sure it was meshing right. Seems to be ok. I inspected the teeth o. The flywheel and they donít look chewed up or anything. When I put the trans in I made sure the torque converter was all the way on. But letís say it slipped a little during install and I didnít notice, would I have been able to still bolt it up all the way to the flywheel? Would it make a horrible grinding sound when cranking the motor it is weíre off a little? I was able to get it bolted to the flywheel fine. Thanks for any advice.
Old January 1st, 2018, 23:42
lawsoncl lawsoncl is offline
Re: Bad grinding when starting engine.
Crank sensor hitting the flywheel?
Old January 2nd, 2018, 00:00
Negative, one of the first things I checked. Thanks
Old January 2nd, 2018, 05:22
old_man's Avatar
old_man old_man is offline
Don't be offended, but did you actually bolt the TC to the flex plate?
Yes it is possible to cram the transmission all the way to the motor without the TC being engaged. Bad news is that if that happened, you most likely damaged the transmission.
So the engine never started? Is the noise only when cranking but not when running? If the starter Bendix did not disengage, the starter will make a large amount of noise.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old January 3rd, 2018, 00:16
Found the problem, one of the oil pump bolts was loose and the torque converter was rubbing on it. Thanks for the replies
Need some real help here with engine not starting ScoobyDooJeep OEM Tech Discussion 30 May 30th, 2011 07:12
starting an engine after sitting redrider2911 OEM Tech Discussion 3 September 21st, 2010 21:25
Grinding sound when starting engine MacTavish OEM Tech Discussion 20 April 11th, 2010 21:02
Grinding sound when starting Muddy Beast OEM Tech Discussion 15 June 7th, 2009 17:47
Grinding noise when starting in 1st, 5spd Glacialbass OEM Tech Discussion 1 August 6th, 2008 20:06
