Old January 1st, 2018, 14:28
fdkss03 fdkss03 is offline
Airbag Light On
Just bought a 99 XJ and it has some small issues I am going through... One being the Airbag light.
When I turn the ignition on, it blinks a few times then remains on. It does not have cruise, and the horn still works fine which leads me to believe the clockspring is still good. I have checked the fuses on the inside of the cabin and they are good as well.
Any other ideas to check on? Next step is pull center console to look at the control module. (not under driver seat)
Old January 1st, 2018, 17:01
trippled trippled is offline
Re: Airbag Light On
You need to see what the code is before you do anything else. Then you will know where you need to go.
Airbag light Vernicious OEM Tech Discussion 13 April 9th, 2017 20:26
Airbag Light i973eat1 OEM Tech Discussion 10 May 14th, 2013 20:59
guages die when airbag light comes on, wtf? check engine light on rockhard4x4 OEM Tech Discussion 9 June 20th, 2009 07:34
Airbag light XJ_Muddin OEM Tech Discussion 11 April 3rd, 2009 20:15
Airbag light on 88XjLaredo OEM Tech Discussion 17 June 11th, 2008 17:52
