Old January 1st, 2018, 14:07
Desert4x4 Desert4x4 is offline
Factory raised transfer case fill plug
Anyone ever seen this ?
Old January 1st, 2018, 14:43
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
Re: Factory raised transfer case fill plug
A pic or better explanation of " raised"
TC cases have had both a 10mm internal hex plug or a 36mm? square type plug.Depends of the year of mfg.
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old January 1st, 2018, 14:54
I was told that raised meant the fill plug was relocated to a area to overfill the transfer case.
Old January 1st, 2018, 15:57
trippled trippled is offline
Never seen that. Why do you think you need to over fill it?
Old January 1st, 2018, 16:43
lawsoncl lawsoncl is offline
I have seen where people have "clocked" or rotated the xfer case so it doesn't hang quite so low, but that would actually raise the level in the case closer to the main gears (which are splash/pressure fed).
Old January 2nd, 2018, 05:42
cruiser54's Avatar
cruiser54 cruiser54 is offline
Yep, I have.
It was a fill plug that had a smaller hole in the plug itself, to be installed with the smaller hole at the 12 o'clock position.
The purpose was to increase fluid capacity for rigs that were towed a lot.
Pretty sure it was only in the first years of the XJ.
Old January 2nd, 2018, 08:08
Originally Posted by cruiser54 View Post
Yep, I have.
Oh, ok that makes sense. Doesn't seem like that would add a lot of fluid, but something. So how high can you fill the transfer case, and is it beneficial? I beat the shit out of my jeep.
Old January 2nd, 2018, 18:41
cruiser54's Avatar
I don't know for sure.
Old January 4th, 2018, 19:15
ehall's Avatar
ehall ehall is offline
ATF expands quite a bit when hot, and the transfer case can get pretty hot (directly bolted to the transmission). Probably need to keep fill level several inches below the breather port.
my '91 beater rebuild
Old January 4th, 2018, 21:27
cruiser54's Avatar
The little bit you gain with that plug isn't gonna hurt anything.
Old January 5th, 2018, 07:25
ehall's Avatar
He asked how high he could go
Old January 5th, 2018, 07:28
cruiser54's Avatar
Fill it through the vent hole. Then, when all the excess blows out, you've got the most you can get in there.
And while he's at it, he should remove his heater control valve.
Old January 5th, 2018, 16:58
ehall's Avatar
And fix his thermister
stripped fill plug in tfer case GoBlue Modified Tech Discussion 4 October 18th, 2010 07:49
np-242 transfer case fill plug. skinner OEM Tech Discussion 10 May 7th, 2010 14:03
T-Case Fill Plug??!!!HELP HenryKrinkle OEM Tech Discussion 9 July 26th, 2009 15:04
Transfer Case Drain/Fill only 1.5 qts?? Sleepydog OEM Tech Discussion 14 September 15th, 2008 22:56
I hosed my NP231 transfer case fill plug rocknxj OEM Tech Discussion 6 December 16th, 2007 16:24
