Old July 1st, 2008, 15:01
RNMedic's Avatar
RNMedic RNMedic is offline
NAXJA Member #659
Ford 8.8 bent shaft or bent axle
Okay whats the easiest way to tell if I have a bent shaft or bent axle housing? got some rubbing from the rear axle. 88XJ with 4.5 lift drop brackets 99 Ford 8.8 rear and new brakes/rotors all the way round. No Trauma that I am aware of. spring perches were supposedly welded on with small frequent welds/cooling to prevent distortion.
TIA John
Old July 1st, 2008, 15:09
razdrvr's Avatar
razdrvr razdrvr is offline
Re: Ford 8.8 bent shaft or bent axle
what makes you think you have something bent?
Old July 1st, 2008, 15:14
RNMedic's Avatar
NAXJA Member #659
had it up on jackstands, with someone in it to check the new speedo gear. heard the rub and rear left looks crooked.
Old July 1st, 2008, 15:24
razdrvr's Avatar
If the tire apears to wobble while it spins then it's the shaft, if the tire runs pretty true then it will be the housing.
Old July 1st, 2008, 15:27
RNMedic's Avatar
NAXJA Member #659
wobbles. Is there anyway to confirm this when I get it out??
Old July 1st, 2008, 15:30
razdrvr's Avatar
use an angle finder to see if flange is perpendicular to shaft.
Old July 1st, 2008, 15:32
RNMedic's Avatar
NAXJA Member #659
thanks, I also have a big rafter square. Guess time to pull the rear axle apart again
Old July 1st, 2008, 17:29
RCP Phx RCP Phx is offline
Are you serious?You need to put a dial indicator on the flange and check for run-out.
Old July 1st, 2008, 17:41
razdrvr's Avatar
I wasn't going to assume that everyone had a dial indicator laying around, or was in the market to buy one.
Old July 1st, 2008, 17:49
Point being,if you could measure it with an angle finder or framing square,its bent for sure and you could see it with your eyes,no tools needed!
Old July 1st, 2008, 18:06
RNMedic's Avatar
NAXJA Member #659
always a reason to buy a new tool!!!!
Bent Ford 8.8 Sideshow NorthWest Chapter 16 June 6th, 2008 11:56
Bent Axle Ears? xj-grin Modified Tech Discussion 6 April 11th, 2007 22:51
Bent Front Axle Jerms Modified Tech Discussion 6 April 16th, 2005 20:29
Transfer Case Main Shaft Bent? Matt99XJ Modified Tech Discussion 17 September 27th, 2004 21:42
bent axle/shaft questions kraziexj Modified Tech Discussion 6 January 16th, 2004 17:38
