Are the RE1130-Gen3 Discos Noisy?
BALTANAKT
Berthoud, CO
Hey All,
I am in the process of building sort of an OEM+ or superstock XJ, and I am installing an OME lift at the moment. The kit came with RE1130-Gen3 Discos, but I am worried that if I install them, they will be super squeaky. My old XJ had some home made disco's which were great, but the noise drove me nuts after a few years. Will these guys do the same thing?
Thank you.
are these the ones that use a small heim at the sway bar? if so, a little bit of white lithium grease once in a while should do the trick.
the gen2 have heims.
the gen3 look like a direct knockoff of the JKS discos.
