When I am driving down a hill and I down shift in my 98 with AW4, if the RPMS get high enough I get a P0107 code saying the map sensor is failing. Goes away after a few key cycles.replaced the map with 2 others but it still happens.
Got around to doing it.
Engine off Key on Orange wire gives me 5.11 volts
Engine off key on green/brown gives me 4.25 volts
Engine on orange gives me 5.1 volts
Engine on green/brown gives me 1.38 volts and jumps up when the throttle is bliped
