Ridered4583
- Raleigh NC
I have a 91 4.0 4x4 auto with some strange symptoms. The gas mileage dropped dramatically and it will intermittently rev to 2-3k rpms for 2-3 seconds with any slight touch of the gas. Even if I barely tap it it will rev then settle back down. This morning after driving about 20 minutes it wanted to stall when I hit the gas. If I eased into it it would go but any real dip into the gas wanted to kill it. About 10 minutes and it went back to normal. On my way home it started out fine then same issue. I actually did die getting going from a stop and would crank but not fire. Got it to fire and limped it easing into the gas. then it cleared again and ran normal. TPS CPS and ECU seem like the most likely options from my research, but thought someone might be able to nail it down a little better. I would be randomly picking one to start with(probably tps because it is the easiest to get to!) Thanks.
