PWRDrill
- Rio Rancho, NM
I have the older style NP231, and I have the transfer case apart. My question is in removing the needle bearings (according to the instructions). There are two sets of needle bearings inside of the main sprocket and I assume these are to be removed along with the metal sleeve that contains them? lt then be metal on metal with the sprocket and the shaft. It seems that if I remove the needle bearings and the sleeve that their in, there might be a little play between the sprocket and the shaft as well. Is this normal or am I missing something?
I searched the internet and the forums and have yet to find a good answer, please help.
Kevin
Kevin
