Solved hard starting problem about a month ago with a Cardone reman PCM. 96 xj 4.0 has run great since. Last night, out of nowhere, it started running rough and throwing random misfire codes on all 6 cylinders. I’ve read the threads, I know there’s a million things that could be causing this, but since I so recently replaced the PCM i’m really tempted to look there first. Is it common for these things to work fine out of the box and fail a month later? Already reset, didn’t help.
