jb98xj
- Millville PA
I came across a cheap MJ recently that I couldn't pass up. Worked fine the first couple of days, but now it won't turn over. The battery is new, the starter is ok, (had it tested), but it won't start with the key. It is a 5sp, and you can coast start it, but when you turn the key, the relay on the inner fender just clicks. Is the relay bad? And help would be greatly appreciated.
