question about axles for 92 xj
blu3fan
Arizona
I currently have an 8.25 rear and its bent from an impact 2degrees.
so I need to replace it.
Drove on it for 8 years now. and its bytime I fix it.
While I am in there I am going to be putting a bastard pack in.
I know there is a 27 and 29 spline axle
Is it best to keep the 8.25 ? and anything I need to look for before I just start cutting a junkyard one up ?
The 29 spline Chry 8.25 is much better than the Dana 35, and much easier to find than the Dana 44. Find one with the correct gear ratio, inspect the gear oil for no metal sparkles, and the gears for excessive wear or damage. Bolt it on.
So after some research I have found I think I have a 27 spline since it's a 92.
Where is the real difference? Do I need a different shaft. ?
The difference is the axle shaft dimensions, meaning the 29 spline axle shafts are a bit stronger. The outer axle housing dimension are exactly the same, 27 vs. 29 splines.
Okay. I got it now. its talking internal splines.
makes sense now. more surface area. hence stronger.
So Ideally I want a 97+ 8.25.
As far as gears go I need to look at mine and see what it says huh ?
I got the aw4 and the 4.0 but unsure if the laredo has the towing gears. I do not think it does.
Believe its 3.55~ or whatever the standard jeep one is.
Ill check back.
Pick a part has 50% off this weekend :) so I might get an axle. and some s10 leafs for a bastard pack :)
