Prev Previous Post   Next Post Next
Old January 9th, 2018, 12:41
coltsandmudilike coltsandmudilike is offline
Intermittent crank no start w/ new cps, cam sensor
1998 Jeep Cherokee 4.0 4x4 234k
​​​So I got one for y'all. I've thrown a bunch of new parts at this and had it running for a couple weeks and now I'm right back where I started. It started this morning no problem, ran great, but now it won't start. While running it does have a check engine light but my scanner is not compatible.
PO did cap, rotor, plugs and wires around 5k miles ago.
The fuel gauge and voltage gauge do not work right now, but when they do it will fire. Very rarely will it start with them "dead."
Initially I thought it was fuel related so put in a new fuel pump no dice. Tested the pressure at the rail and it's good. Checked all relays and fuses they looked good. Did replace one for the starter relay. New battery terminals and cleaned the grounds. And a brand new battery when I first bought it.
Moved onto the crank sensor still nothing. It was a Mopar too. I cleaned the NSS. Then a new starter. Then a new camshaft position sensor seemed to do the trick. That lasted for a couple weeks now I'm back to square one. Sometimes if I leave the terminals disconnected for a while the gauges work and she fires. I don't have a clue what do you guys think?
Another P1391 code post. cam sensor? dist? crank sensor? LockdUpXJ NorthWest Chapter 8 June 7th, 2015 09:52
Intermittent No Start, Not CPS Nevada City Sparky OEM Tech Discussion 19 June 24th, 2013 07:46
Crank Sensor replaced still no start LiteEmUp OEM Tech Discussion 32 December 28th, 2009 15:48
Replaced the crank sensor. Still won't start. newjeepowner OEM Tech Discussion 5 August 5th, 2009 20:42
crank-crank-crank-crank-cra... [wait...] crank-crank-START! iBran OEM Tech Discussion 20 October 21st, 2005 18:33
