Old February 14th, 2010, 09:37
2000bluexj 2000bluexj is offline
Trans Mount
I have a 2000 cherokee and just bought a new Trans Mount. My old nuts look like they are 5/16-18 however the new studs look like they are 5/16-24 fine thread. Can i just use a regular nut on it, or do I need a flange nut like the factory one?
Old February 14th, 2010, 09:49
Apostle Apostle is offline
Re: Trans Mount
you can use a regular nut, but would also add a lock washer and reg washer.
been a while since i looked at it, but think factory is the self locker type
Old February 14th, 2010, 09:59
Re: Trans Mount
It seems impossible to get a washer up there with the crossmember
Old February 14th, 2010, 10:01
Re: Trans Mount
try a bit of grease. slips, but also acts as a soft glue: nut/grease/lock/grease/washer
Old February 14th, 2010, 12:26
Re: Trans Mount
I may just tack weld a washer onto a nut.
Old February 14th, 2010, 13:38
Re: Trans Mount
The original threads are M8X1.25. My mount, although the correct part number, is 5/16X24. I need to swap this one with another at the parts store. And I cannot find 5/16-24 anywhere around here.
Old February 15th, 2010, 11:48
Brown Dog Brown Dog is offline
NAXJA Supporting Vendor
Re: Trans Mount
How did you determine the bolts supplied are 5/16-24? M8-1.25 is very close to 5/16-24. It would be easy to get them mixed up. 24 thread is the common fine thread on a 5/16" bolt (source Mathinery's Handbook). However, since the M8-1.25 is commonly used on Jeep of all kinds, I'd substitute with the spec bolt: M8-1.25. Might try NAPA or a good Ace Hardware for the correct bolt. While you're there, ask for an all-metal lock nut. Jeep used a locking nut on the original. Use a washer with it since the flange nuts are difficult to locate. As with all lock-nuts, tighten snug, but no more (there are not torque specifications for lock nuts because of the way a lock nut works). Never reuse a locknut.
This wouldn't be the first time we've seen a manufacturer send 5/16 instead of M8...the 5/16 are cheaper and more readily available on the wholesale market.
Brown Dog Offroad High performance engine mounts designed for XJ and MJ.
100% Made in USA - Lifetime warranty.
10% discount paid club members. Code: .
Old February 15th, 2010, 15:24
joe_peters joe_peters is offline
Re: Trans Mount
Thinking the four studs through the crossmember are M8-1.25 as mentioned by the others. I used lock washers with nyloc nuts on mine.
Old February 15th, 2010, 20:33
Re: Trans Mount
I found some flange nuts,non locking. Ill just use some red loctite on them
Poly motor mount + stock trans mount = bad? -88fleXJ- Modified Tech Discussion 11 August 12th, 2009 12:42
NEW O.E. ba-10/5 trans mount Hellbent For Sale: Private Party Only. XJ ITEMS ONLY 1 July 22nd, 2009 17:38
WTB trans mount MTN4X4 SoCal For Sale 1 April 21st, 2008 21:14
ba-10 trans mount? Where to buy? 5.0 Junkie OEM Tech Discussion 2 January 4th, 2005 14:18
trans mount stu's jeep's OEM Tech Discussion 4 November 20th, 2003 16:58
