I currently have a 3" Rusty'a lift with a full length real AAL. I was thinking of adding a RE Budget boost to the mix with the coil spacer and extended shackle.
My question is, will I have to make any adjustments to the T-case? I currently have it dropped and have no driveline vibes. Will adding a budget boost change the driveline angles enough to where I would have to go to a SYE?
Thanks
Thanks
