Old October 24th, 2017, 09:11
Heavyopp Heavyopp is offline
Re: Stubbys Build Thread
I did a towable air compressor a few weeks ago -- Put some clean water in a spray bottle and spray a mist on the entire truck -- Moisture helps cure the monstaliner
24 hours in my garage here in NJ and the liner was still slightly tacky -- barely
I'd say you are safe to move it outside after 24 hours -- I wouldn't drive it for 48 -- Hate for things to stick to the fenders being kicked up by the tires
Keep misting it whenever you can, can't hurt and only helps cure -- Complete cure in 7 days -- one tough finish
What color -- Desert sand?
Old October 24th, 2017, 11:57
Fingerless Fingerless is offline
Medium Quartz Gray. Iíll post pictures later!
Thanks for the tip on the water bottle. Iíll snag one from the wifeís stash!
Old October 24th, 2017, 22:39
Greenz's Avatar
Greenz Greenz is offline
I just installed the THOR cowl intake. Love it so far. The cabin noise is no big deal.
You did a great job on the Monstaliner. I did a motorcycle in 'Lady in Red' two years ago. Its holding up great. No fading, rock chips, or scratches.
Old October 25th, 2017, 08:39
So what did you use to prep -- Is that something sprayed on the black before Monsta?
Did you roll or spray? How much monstaliner did you end up using? How about the door jambs?
I'm really thinking changing mine to Dirt Bag sometime soon
Old October 26th, 2017, 17:47
Sanded down the entire jeep with 80 grit. Had some bare metal spots afterwards so I hit the whole thing with some self etching primer then scuffed again with the pad included in the kit.
Rolled it on after cutting in with the brush.
I did not do the entire jamb. I opened the doors during the second coat and rolled a little on then. I only ended up using just over a gallon. I would say a gallon and a quart would have been plenty.
I did measure and divide out my second gallon and only used a quart out of it. So I have 3/4 still that I can mix and use down the road if needed. (Jambs, touch up)
Old October 26th, 2017, 23:33
So you where able to measure out the color and the hardener to make a quart out of a gallon
Thats good to know it's possible and still get a color match
Old October 26th, 2017, 23:56
Yea. I did borrow some measuring cups from a buddy who owns a body shop though. Made it a lot easier. He also threw the gallon, color and hardner all in his shaker for me before I divided them up!
Old November 3rd, 2017, 01:13
Well no work done on the XJ this week but got some work done on my arm. Finished up my lower sleeve!
Also had my TECC refresher this week. Love it as always! Just a pic of my rig before class!
Old November 3rd, 2017, 02:39
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
Sweet looking set up. TECC/TCCC is some fun and practical stuff
Old November 11th, 2017, 13:20
Well I decided since Iím stuck on shift for the next 48 Iíd get some more done since I can pull my jeep into the nice heated truck bays!
So I got my Affordable Offroad sliders installed!
Now that thatís done weíre washing all the rescue rope. Ugh. 600í ropes suck. Lol
Yes thatís one rope on the drying rack!
Old November 29th, 2017, 20:18
Front bumper from Hardcore Offroad installed! I donít have access to a welder but know the welding instructor at the local Votec on a personal level so I dropped it off there to be done! Cost $18.00 in consumables!
Also finally put in my IRO gear box spacer while doing the bumper.
Didnít get a lot of pictures this time. Didnít have a third hand!!!
Here it is on the floor of the votec floor.
Primed and ready for flat black
And finally installed. Iíll get better pictures outside tomorrow!
Old November 29th, 2017, 22:11
Wiser's Avatar
Wiser Wiser is offline
Looks awesome, Loving the build
2018 Jeep Cherokee KL
1 ton Tube Buggy
1973 C20 tow rig
1991 XJ 2Door
My XJ build thread dantheman! Modified Tech Discussion 86 January 24th, 2017 08:55
O.K. B's Build Thread OutkastBoss Midwest Chapter 171 October 23rd, 2016 18:48
Another MJ build thread ... blondejoncherokee Sierra Chapter 280 June 24th, 2016 19:53
New to the thread/ New build kybray44 Sierra Chapter 5 March 8th, 2010 23:04
chrome alloy 44rear & 30 inners & stubbys Dano Wanted: Private Party Only 1 February 12th, 2007 13:43
