skipc
- Georgia & points west and south
Has anyone tried to make a battery cable with (2) 2 or 4 ga wires of off it? Either using the clamp type or by taking a pre-made one and soldering a second wire to it? The clamps are made of lead, so solder should melt right in, right?
At the least, I'd like to run a ground right from the battery to the frame AND the block at the same time, rather than chain them together on studs. I'd probably want to do that to take +12 to my inside tie point too. Avoid all the future corrosion issues with bolts and nuts...
Sound like soldering is a good thing for lead clamps?
